The command configures the keep-alive and hold timer intervals of the MSDP peers.
| peer all | Specifies all MSDP peers. |
| remoteaddr | Specifies the IP address of the MSDP peer. |
| keep-alive-sec | Specifies the keep-alive timer interval in seconds. The range is1–60 seconds. |
| hold-time-sec | Specifies the hold timer interval in seconds. The range is 3–75 seconds. |
| vrname | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
You can use this command only when either MSDP or the MSDP peer is disabled. The hold timer interval must be greater than the keep-alive timer interval.
The following example configures the keep-alive and hold timer intervals for the MSDP peer 55.0.0.83:
configure msdp peer 55.0.0.83 timer keep-alive 30 hold-time 60
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
